serpentine belt replacement
torcano
Does anyone know the part number or specs for replacing the serpentine drive belts on a 4.3L MPI Mercruiser? I don't see it in the service manual.
achris
More fish than mountain goat
Re: serpentine belt replacement
Need a lot more information than this... Year, serial number, standard or closed cooling, belt driven or leg based seawater pump, Alpha or Bravo drive?
Chris.....
torcano
2002 Mercruiser 4.3 L MPI. Standard cooling, belt driven seawater pump, alpha 1, gen II drive. Not sure about serial number.
Ayuh,.... Alphas use a drive mounted pump,... Whatcha really got,..??
torcano
Sorry. The raw water pump is in the lower unit of the Alpha 1 drive. I think there is also another seawater circulating pump in the front of the engine as well.
torcano
Thanks. I actually have the service manual, I was looking for the replacement part number. I figured it out. I removed the belt and sure enough the number was stamped on the back of the belt. One problem solved.
racer6686
Do you still have that number handy thanks
Don S
Welcome to iboats racer, you need to start a new thread of your own, post your engine serial number and what you need and i'm sure your question will be answered.
bionicjumpy
Can you help me by let me know how can I remove the serpentine belt, please???
Don S
You need to start a new thread of your own bionic, and post what your engine is and it's serial number.
