pursuit2460
Thread starter- Joined
- Aug 24, 2004
- 193
Where do I start. Well I started by removing all the bolts that hold up the lower unit. The lower unit only dropped about 1/4 to 1/2 inch it would not go down any more than that. I started putting some presure on it with a crow bar. While I was putting little presure on it and trying every and anything to get the lower unit to drop I saw that the water pump housing was flexing up everytime I andded pressure to the lower unit. So I decided to brake the housing. After I did that the lower unit dropped. I cut the blades of the impeller to make it easier to handle and to get it out of the metal housing it spins in. No matter what I tried the impeller would not come off. It would only move up or down about 1/4 inch. Finally decided to cut the impeller in half to get it out. Now heres the problem the new impeller will not go on. The manual says that the cam lock I think thats what its called the little white piece that locks the impeller to the shaft. Anyways it says that the sharp edge must be the leading edge with the shft turning clockwise looking at the shaft from the top. The impeller can only go on one way and it wont. The impeller has two different sides one side is open the other side has like alittle lip on where the cam lock is suppose to slide though. With the water pump installed on the lower unit that little lip wont let the cam lock slide though. The only way that the cam lock looks like it will slide in is by fliping the impeller and the cam lock. Any adivce has anyone had this problem. Should I filp the parts what do I do. Its a 93 Johnson 225 and the water pump kit was a 5001594 THANKS
