FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Look for a nickel sized convex aluminum welch plug on the top of the engine block and/or for a 1" X 3" aluminum plate on the side of the port transom bracket.
The 1969 85HP and 115HP are built on the same motor with a slightly different engine in terms of displacement, bore and stroke. The carburetors are different.
See if the welch plug is hidden uner the paint where I have circled it. If it is still there, you could try cleaning it with acetone. The numbers will be stamped in.
Also - it's not a Johnson. The cowlings, upper & lower, have the Evinrude shape. Johnson's lower cowlings didn't adopt that shape until about 1974, at which point the uppers became interchangeable. Not likely someone swapped out the lower cowling on this one to install an Evinrude cowl...
- Scott
