Serial # ID
RafnsonL
I have a older Evenrude outboard I believe is a 9.9 HP The only number I can find on it says its the Serial # that is 10302E-E02024 Does any one know how to find the Model and year from this info ?
BEERSTALKER
Re: Serial # ID
there are links in the sticky section or top secret files they say its a 1963 motor
Vic.S
Re: Serial # ID
10302 is the model number for a 1963 10hp
RafnsonL
Re: Serial # ID
Do any of you have any idea where I might find a flywheel for this motor?
There was a wire from the coil to the points pinched and shorted out. I used the wrong type of puller to pull the flywheel, and cracked it all the way around the hub and don't want to put it back togeather this way!
I haven't been sucessfull finding any sights that list parts for these old units.
bktheking
Re: Serial # ID
580218 is what you need, none on ebay right now.
Go to AOMCI.ORG and create an account. Go to the webvertize portion of the site and ask if someone has one for you.
