Self Boat Launch Help
Bassn7
Anyone use a retractable rope reel? Type? Ideas? Thanks. (18 foot bass boat)
Watermann
I've not seen a retractable rope reel, just ones for cord that I really wouldn't trust a great deal. If there was one for 3/8" rope it would be pretty good sized I would imagine. Do you have a link to one?
wrench 3
I launch my 26' by my self. I just tie one of the bow lines to the rear of the trailer and then after it's floating I pull the trailer forwards to take the slack out of the line. It always works good for me.
keith2k455
I launch by myself every time. If your ramp had a dock, just be patient and utilize the dock. Do some searches for etiquette and make sure the boat is loaded before going down the ramp. You'll be fine, just beer patient and check everything twice the first few times.
roffey
I think beer patient is just sit back and relax, have another beer. Me personally I prefer rum patient. I do it all the time, kind of a hobby, LOL.
fhhuber
I tie a rope from boat to the trailer winch in case I back too far.
I try to get it so the back end is light on the trailer and the front is still sticking to the bunks. 6 inches too far or a big wave and the boat will float off...
Back it up.
grab the rope and move the boat quick
Tie it up.
Then move the truck and trailer off the ramp.
JimS123
I always launch where there's a dock...
* I back in until the transom just touches the water. (then I can stand at the winch without getting my feet wet)
* Tie the stern line to the last cleat on the dock.
* While holding the bow line, disconnect the bow tie down and winch line.
* Give the bow a slight push.
* Walk down the dock and stand at the first cleat on the dock.
* As the boat drifts by, tie the bow line to the first cleat.
* Pull in the aft line and retie it to snug the boat against the dock.
* park the car.
On retreival...
* Before backing the trailer in, pull out the winch line and attach the hook to the u-bolt mounted on top of the trailer fender.
* Back in until the last roller touches the water.
* Untile both lines - while holding the bow line, tie the end of the aft line to the dock.
* Pull the boat up to the trailer and attach the winch line (its already at the convenient spot)
* Bring the stem up so it just touches the last trailer roller.
* Crank the winch - until the boat is on the trailer.
(this may require going back and forth an extra time of 2 if the water is wavy at the time and the stem wants to jump off the
roller)
* Fasten the bow tie down.
* Untie the aft line and stow it in the boat.
* Drive off the ramp and fasten all of the other tie downs, secure the motor, etc.
Old Ironmaker
I'm a bit slow so I'm not getting something. How do you untie the line at the end of the trailer when the trailer is under water?
When docking solo guys that are waiting in line are more than happy to tie your boat off when you pull out. Just make sure they know how you want it tied off and to where.
Maybe a bit off topic but there is a Marina here that will launch your boat for you and Valet park your trailer. Or you launch it and with a kid in the water will walk it to the dock and tie it off if you want to park your trailer yourself, they follow you to the parking lot in a Golf cart and drive you back to the dock. All this for $5.00 to launch. They can get you in and out in no more than a few minutes, marvelous. It's not uncommon for them to launch 100 boats or more in a day.
wrench 3
I've got 25' bow lines, so by the time I get the slack out of the line the trailer is clear of the water.
I use a local government gravel boat launch just down the road from us and pretty much off of the beaten track. Unless some one is walking their dog there's usually no one around. It only gets busy if there's a bass tournament on.
fhhuber
The trailer WHEELS are under... but the tongue and winch are where I can stand without getting my shoes wet.
jayhanig
Master Chief Petty Officer
I clip my bow line to one of the rings on the back of my truck, then back the trailer into the water until the trailer fenders are underwater except for at the very top... about the space of an adult footprint. I put the truck in park, set the emergency brake, and get out. Then I unclip the safety chain and release the winch so it can free wheel and give my boat a push. Once it's loose, I unclip the bowline from my truck and walk alongside the boat while pulling the boat backwards (I'm standing at this point on the dock; not in the water. Once it's at a good spot along the dock, I tie it off fore and aft to the dock, then go move my truck to the parking lot.
thumpar
A lot will depend on the boat and trailer. With my last boat I could do it even when there was no dock but with my current boat it would be hard. It sits 1.5" above the fenders on each side and if not careful it will sit on one. The trailer is a green color so once it gets in the water I can't see it.
fhhuber
This is why they make bright reflective tape, lights and guide poles.
thumpar
I have wanted guide poles but since my boat is 8'6" wide it would technically make it to wide without a permit on the road.
