sparkyz450
Thread starter- Joined
- Mar 13, 2011
- 2
Hi guys, I'm new to the forum and a new owner of a project boat. I've been reading all I can trying to get stuff figured out and am looking for any recommendations. The boat we purchased needs a new lower unit. The motor is a 1974 Mercury 115 inline 6. While looking for lower units we have decided to probably buy one from an 80 horse, which from my understanding has a 2.3:1 ratio.
The boat is also going to be operating mostly around 6000 ft elevation. The hull is an 88 Thunder Craft Capri 152. From my research its weight is 750 lbs and the motor weight is 273 (info from this website). I'm guessing the total loaded weight will be about 1700 lbs.
We don't have any props we will be able to try first so I'm trying to get as close as possible with the first try. From my calculations, based initially off of a recommended prop for the stock 115 motor, I came up with needing a 24 pitch prop to be approximately equivalent to the 19 that was recommended by the calculator, factoring in gearing change to the new lower unit. So then accounting for altitude I'm thinking a 21 would be a good starting point...
Does this sound in the right ballpark? Thanks for any help and I will be happy to provide any more info needed.
