OverLabyss
Thread starter- Joined
- Jun 30, 2020
- 1
over the winter i bought a 1967 Mercury 500 outboard to put on my 1966 Lonestar. i need to put new seals and gaskets into the lower unit but the prop is not coming off the shaft. I've let it soak for a few weeks in various fluids (PB blaster, Diesel, & acetone/ATF mix) and it still wont budge. I also heated the prop shaft up lightly with a propane torch.
Any suggestions on removing it without completely destroying the prop since its an 11 spline hub?
[size=8pt]ไฮไลท์บอล[/size]
