DanNeedsHelpWithBoat
Thread starter- Joined
- Mar 29, 2016
- 20
Hey, anyone have any advice on getting out one of the vertical bolts that run through the lower unit? The manual says they will seize and you need to cut through them, which I did on the one that is seized. I figured I could just weld over the cut in the aluminum housing. Ive tried Sea Foam Deep Creep mixed with heat from a torch and hammering, Hasn't budged a bit!!! and now the head it s a little bent! Or does anyone have a lower unit from a 1964 40HP Lark 7 electric shift they want to sell?
