Seized 454
HT32BSX115
Re: (no longer) Seized 454
What fluid should be used in the KC outdrive?
Thanks
I would use Mercury high Performance synthetic gear lube or even Amsoil syn marine gear lube. Bond-o would use Mobil 1 synthetic gear lube, truth be known, use any good synthetic gear lubricant.
So far, I have noticed that Mercury and Amsoil actually "claim" their marine lubricant will still work with 10% water contamination .................and truth be known again........they all probably still work with 10% water contamination.....
fill per the OMC factory (don't fill from the bottom, correct?) manual prior to installing engine.
I do not know about the cone clutch Cobra. The OMC service manual was very specific about filling dog clutch Cobras from the fill port.....some people have advocated filling them from the bottom until oil comes out the "FILL" port and then continuing filling from the fill port..........Enough people have done it to probably verify that it works.....(I would still do it like OMC said to do it.)
If you have the OEM OMC service manual for your model drive, fill it like it indicates. Don't believe what Clymer or Seloc says. If they're wrong, you get to buy another drive.
Make absolutely sure that you get the right amount of oil in the drive. run it a little and let it rest for the bubbles to rise to the top and top it off.
sam60
I forgot to mention that I found another issue. I decided to pull the starter apart to see if I could rebuild it due to the open field when tested. The long cover bolts broke while removing and the entire inside was rusted as if it were under water for some time. Apparently, the PO had problems with using the drain plugs and/or replacing the bilge pump. Getting into the outdrive this weekend. (supposedly rebuilt just prior to the engine failure)
This is where it get's scary.
HT32BSX115
Yeah. People leave boats sitting outside and they fill with water because the drain plug is left in or they fill with water because something gets stuck in the drain.....
Um.....yeah.
sam60
when is the splash?
Soon I hope. Maybe 10-15-11? Wifey and I have plans to celebrate our 30th on the water from 10-29 thru 11-1 and need to do at least 1 day test.
Launch from Temple Bar.
