KJDbonez
Thread starter- Joined
- Aug 8, 2015
- 2
I bought a 1985 Johnson 4hp at a garage sale recently for $20 although the guy said it wasn't working. Apparently it ran fine 3 years ago and then the following season the pull-start wouldn't pull, so it hasn't been ran for a couple years. It looked like there was some broken plastic in the recoil spring housing so I took that off, but even with that the flywheel wouldn't turn. I took off the lower unit to see if that was the problem and that does not appear to be seized, so I'm assuming its coming from the powerhead. I removed the cylinder head and it doesn't look like there is any rust or metal shavings or anything in there (there is some soot that fell off the cylinder head when I removed it), but in the lower of the two cylinders there was a small amount of fluid (possibly water) in the dependent portion. I positioned the motor so the cylinders are vertical and put some Marvel Mystery oil for a night and tried to turn it, but there isn't even any play in the flywheel. Also the oil hasn't drained at all around the piston in the lower cylinder. The piston in the upper cylinder is positioned deeper into the powerhead and the oil did drain out of the cylinder. I got some PBlaster and sprayed that into each earlier today as Ive seen some people on here say to do, and again the fluid isn't draining at all in the lower cylinder. From what I understand after reading some posts on here is that I have two options (1) tear it down and replace what needs to be replaced in the event that water did get into the powerhead and (2) continue to soak in PBlaster or Marvel Mystery Oil or the like and try turning the flywheel and see if it opens up over time. My questions are:
Is the fact that there is no play whatsoever in the flywheel a giveaway for a specific problem?
If in fact water got into the powerhead and there may be rust somewhere, what am I looking to replace at a minimum? I'm new to working on outboards, but I have the OEM manual and I'm pretty good at following directions.
If I decide to wait and continue with using a catalyst and/or lubricant to work it loose is there anything else that I can be doing to expedite this process? All I'm doing is using a wrench on the flywheel nut and turning. And if it does open up and eventually I get it started then do I just run the engine with a richer oil:gas ratio for a while?
For what its worth I did take the carb apart, clean and rebuild since the kit was cheap and I took the lower unit apart to check out the water pump and lower gearcase which was all in good condition. So assuming I get the thing turning I don't think there is a lot of other work that needs to be done.
