I have a set of seats with molded plastic bases. Ive done a bit of research and found the bases have been known to crack in a few places. They are "flimsy" - they lean back more than I think they should. Last summer I put a piece of sheet metal under the base of one. So far no issues. However, the sheet metal does not support the seat back mount, just the base. I want to replace that with a panel that will let me tie in to the seat back support bracket.
Any ideas on what thickness aluminum to use so it is rigid and not too thick/heavy? Id like the seats to hold up to some heavier and/or less careful passengers so Id rather go too thick. Im not real sure where to start, though. The steel sheet metal there now is around 1/16" and is too flimsy. Im thinking maybe 1/8" aluminum to start? Thicker? Or is that overkill?
Id like to do the plate reinforcement now while the seats are solid to keep them from breaking.
