Re: seat mounting
I do it about the same ,except I put the floor base of the seat on a piece of EXT. AC ply, mark for the bolt holes, then take a 1" by 2" scrap of wood and draw the cut out circle 1" larger all around the base. Cut the circle and drill the bolt holes. Using carriage bolts. I run them up from the bottom side of the board, thru the base plate, tighten the nuts to suck the bolt heads flush on the underside. Put hacksaw marks on all the excess thread of the bolts. Take bolts out. Cut excess off. Mixup a little epoxy, coat the bottom of the board only, then finish sides and top. One at a time coat each bolt head and the depth of the threads in the wood. Put bolts in board and assemble it. Epoxy the wood base to the deck. That way you can remove seat and base to do repairs.
