sears ted williams outboard what horse power
milktruckman
i was left a sears ted williams outboard motor and a jon boat.
motor is not running.
has no model number or what horse power it is.
i dont know much about boat motors so need some help to identify this motor for parts and book. hope someone can assist.
looks like a smaller motor but could be wrong. by pictures on ebay of manuals looks like some of the 5 and 5.5 but just not sure.
has points,condenser,armature.
off,start and run lever moves armature closer and farther away.
engine all white. has tin skirt. manual pull choke carb. choke pull through plastic plate
engine flywheel has fins so i figure air cooled.
i feel like maybe its a tecumseh by look of carb. i could be wrong.
gas tank built in top.
motor has handle for steering but no twist throttle.
no idea of year or model number
like working on old engines and would like get it running.
needs a prop also
thanks for any help
great forum
M
mrcrabs
Guest
Re: sears ted williams outboard what horse power
Welcome to Iboats,
I guess if the are no numbers the only real way is to pull the head and measure the bore and I can tell you engine model and hp.
I think anything under 4.5hp used a pickup tube for water cooling...all of that depends on year.
Can you post a picture?
milktruckman
sorry no numbers, looked but no tags.
i can post a picture and will do that. you want whole motor view or a certain area??
thanks
M
mrcrabs
Guest
post what you can like a side view and good shot of the carb area
milktruckman
i was trying load them as slide but could not so added them as attachment.
im hoping someone can identify and come up with a model # and size so i can get parts and a prop.
i have a few more pics i can add but 5 was their limit.
thanks
M
mrcrabs
Guest
I know its a sears simpson model made in Canada, but I'm unsure of who made that powerhead...need a side shot of the block and cylinder head, I don't believe I every saw one with that shape of exhaust before.
Edit: here is a McCullock Model 574-59660
http://cgi.ebay.com/ebaymotors/Vint...9015352QQptZMotorcyclesQ5fPartsQ5fAccessories
SEARS MOTORS with Model Numbers other than 217.???????? where built by:
225.?????? Chrysler Outboard
574..????? McCullock Outboard
Parts for McCullock
Outboard are No Longer Available
Some Parts for Chrysler are avalible on special order only.
milktruckman
ill get some pics saturday during day and post. maybe ill have some luck finding a book and parts for this with your help once done.
i looked on whole motor and only thing found on carb was LMB
only thing on block was a #7884 stamped in block.
new info just found while cleaning carb. on bottom of bowl it reads
walbro usa not sure if its the 1 that came with it but it fits hope you can answer that 1.
thanks
steelespike
It is a 4hp McCulloch.Does use A walbro carb years 65-69.Uses Champion J18Y or modern equivlent. Points set at .020. Air cooled power head,Water cooled leg with a rotor above the gearcase water misting out the 10 vent holes on the leg.
milktruckman
steelespike, any ideas on model numbers, if parts can be found or a propeller/prop for this motor. ?
its on a small 10 foot jon. it would be great for the small creeks and ponds here.
how did you know this motor.?
so those little holes spray water .:rolleyes:
mrcrabs, heres are the block pictures.
thanks
Hermie02
I just got a 4.5 Ted Williams outboard motor is there any site out there that could tell me what year it is
Hermie02
Here are the numbers on the motor 21758580 and106050
truckintyler
i have that exact engine,mines a 4 hp sears 1968 works great
M
mrcrabs
Guest
hermie sort of hijacked the McCulloch thread there Steelspike
