Sears Ted Williams 7.5 Mod # 217-58880 Fuel pressure problem
chigg4142
Have installed carb kit, set float travel "level" upside down, flat bottom of bowl opposite float hinge, new fuel pump bladder set at 2-8 o'clock. (Will start then "sput"). Carb bowl is full. Spark plug is dry after cranking. Any suggestions are welcome. (This thing is not going to get the best of me, haha).
RCO
If your float bowl is full, the problem is not with the pump. Are all the passages in the carb totally clean?
chigg4142
Not totally sure.
Will let soak in carb cleaner then blow with air.
Thanks.
