rockmonkey
Thread starter- Joined
- Dec 1, 2013
- 25
howdy. I just picked up this motor for 50 bucks. seems to run ok, but rough. Ive cleaned the float bowl & pin , most of the carb while still mounted and checked the flapper on the gas inlet side. Ive cleaned the bolt on the bowl and jet on the bolt as well. It'll run a bit choppy but will keep going as long as i play with the throttle. After about 5 minutes of running, the gaskets around the head start bubbling and it starts smoking pretty good. still running, but getting choppier, so I cut the gas and shut her off. It'll start up again after a couple pulls and run fine for a while, but same thing. It was also dripping gas through the lower unit earlier, but may not have had the throttle shut off all the way. Any ideas, or does anyone have a pdf manual handy? Any help would be appreciated.
