Sears 3.5 model # 60920 093193B
Status
Not open for further replies.
jimbobmt
I'm trying to determine the year and manufacturer of my 3.5 sears outboard motor.
Tom @ Buzzard Bluff
Re: Sears 3.5 model # 60920 093193B
I don't even know where to start with those #s! A Sears model # should start with a 3 digit prefix followed by a . or space followed by a longer series of numbers.
Maybe someone else can decode what you sent but in the meantime look for a prefix.
jimbobmt
I have run into the same problem. All the searching I've done requires a 3 digit # with a . followed by numbers. The number I listed is the first 5 above the other seven.
Thanks for your reply.
M
mrcrabs
Guest
Look by the carb for a engine tag, and could you post a picture?
jwh
Hi!
I just purchased a 3.5 HP Sears also. It also does not have a prefix # and has after model # 60940 105674B. I am also not finding any information on it. Sounds like the same motor. Mine also says on tag Sears roebuck & co. USA and simpson sears limited-canada. I did find a #574 on the powerhead. Think might be a clinton engine.1965-1968. But not positive. Think its air cooled but not sure . Keep in touch and I will do likewise. Maybe we can get this thing figured out. John johncarol@wavecable.com
Tom @ Buzzard Bluff
Hi!
While it may be an anomaly or casting number 574 is the prefix for the West Bend built Elgin series from Sears. IIRC (and that's a while back!) the 3 1/2 West Bend/Elgin was the first in the water-cooled twin series shortly following WW2. AFAIR all of the Elgins were painted a light 'pea green'.
If your motor is air-cooled it will have multiple distinct fins on both cylinder and head. If not present then it is water-cooled..
I tried to find the website for the Elgin group on the AOMCI homepage but the link they list is inactive. Might be best to post a question about Elgin contacts on the AOMCI 'Ask-a-member board at:
<http://www.aomci.org/cgi-bin/yabb2/YaBB.pl?board=askamember>
The website is open to the public and requires no registration. It is incredibly helpful and manned by a group of EXTREMELY knowledgeable people. They have came to my own assistance numerous times. Tom
Edit: Afterthought Dept.:
Both you & the OP might try getting in touch with Doug Penn:
<http://penn.itgo.com/>
He may have used parts for your motors, can help you identify them and may be able to put you in touch with the AOMCI Special Interest Group that is applicable. But it would be great if both of you could post pics here as 'mrcrabs' suggested. If you will I confident we can help you identify what you have.
jwh
Hi!
I have the 3.5 Sears Roebuck & Co.USA Model# 60940 105674B. It also has on tag Simpson Sears Limited-Canada. I had said that the powerhead had a # on it(574)must of had my eyes crossed, it's actually 582. Going to try to attach photos with this message. Thanks John Motor has bottom cowl off.
F_R
1970, Sold by Sears of Canada (Simpson Sears). Made by Clinton.
TopWake47
1970, Sold by Sears of Canada (Simpson Sears). Made by Clinton. This is what I rigged up 😁..works tho.
HI, anyone know where to find a fuel coupler for the 1970 sears/Clinton outboard shown in the pics ?
Status
