I have a Stratos fish and ski and get quite a bit of water in the boat when moving. It appears to be coming in at the seam between the upper and lower hull. The prior owner put silicon caulk it the area under the seam cover which is now loose and coming off. What is the best method to repair this? Clean and re-caulk? I there a sealant better than bath-tub silicone?
