Should there be some sort of sealer between the hull bottom and the cap? I bought a 1976 18.5 ft Hydra sports bass boat from my uncle who 2 years ago separated the cap from the hull to replace the floor and the transom wood. When he put the cap back on it appears he didn't use any sealer in the seam. He didn't put the rubrail back on so removing all the screws would be no problem.<br />The reason I ask is that after a high speed run I have about 10 gallons of water in the hull, which the bilge pump easily gets rid of. I can troll all day and not get any more water on board until I make another high speed run. My assumption is that when running fast water spray is coming in under the rubrail seam. Am I on the right track or should I be looking somewhere else?<br />Thanks, Devon
