Seaking-what year?
rustyscrew
I just got a 15hp seaking. model vwr52119, serial # 97X20892.
1) what year is this? (from other posts, I gather it to be from 1981-83)
2) What carb kit should I order? (Iboats has 4 different 15hp kits- not sure the distinction and I don't have the manual yet- will order once I know the year)
3) Will Champion RL-86 plugs work? (not the factory specified, but I think I found that they are compatible)
rustyscrew
Re: Seaking-what year?
Thanks Gerry,
I thought that might be a "B" but it was stamped right on the line and hard to tell.
There isn't a letter on the end of the model number, so it looks like I have a 1979.
I would like to order a carb kit at the same time as the manual, but I am unsure which kit is right for a 1979 15hp Seaking.
Anybody know which one I should order? (http://www.iboats.com/Chrysler-Carb...5388968--**********.133253434--view_id.270422)
and
Thanks in advance!
carholme
rusty;
Can you tell from your carb if it has OM or WB model identifiers on it?
Gerry
rustyscrew
Gerry,
I can't see much anything that indicates OM or WB. On the top of the carb mounting plate (where it mounts to the block) it says: CO-10B and 4720611. Got excited there for a second then realized that I can't make much of it.....
where would it say OM or WB?
thanks again!
