Seahorse 6HP help
hoosierdaddy
I have just received this motor from an older gentleman that has has it for years. I cannon find any numbers on it anywhere. It runs well and starts on the 1st pull. However, it just bugs me that I know nothing about it. There is still the starting information sticker on the tiller handle but that's the only thing I can find.<br /><br />
<br />
<br />
<br /><br />Thanks for any info you can give me.
Scoop
Re: Seahorse 6HP help
Look for a model number tag on the transom clamp. Sometimes, they kind've blend in.
hoosierdaddy
OK, it's a CD-23, thanks. <br /><br />I wanted to replace the impellor and seals on the lower. Does anyone know what part numbers I need?<br /><br />Thanks again.
Xcusme
Hoosierdaddy,<br /><br />BTW, cute nick. Looks like you have a 1966 6HP Johnson. <br />Parts are available at your nearest Nappa Auto Parts.<br />Impeller 18-3001<br />Impeller Wear Plate 18-3102 <br />or<br />Repair Kit 18-3202<br /><br />Driveshaft Seal 18-2023<br />Prop Shaft seal...Not shown<br /><br />Double check these parts and Nappa numbers when you order. The Prop Shaft seal can be had from a Johnny/Rude Dealer.
