Seahorse 35HP Water Pump Question
Michael L Pivac
Re: 1957 Johnson Seahorse 35 hp model RDE-RDEL . When does one know if the water pump is bad. When does it discharge water.
oldboat1
Lower unit needs to be immersed about half way up, either in the lake or in a barrel. Spray should come from the exhaust port almost immediately.
If uncertain about the age of impeller, it should be replaced as a caution.
