Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
Picked up a can of Seafoam and did the decarb in the driveway on muffs. Used about 8 oz of Seafoam in 1/4 gal of gas and ran almost the whole thing through, then let set for half an hour. Started it up and ran the remainder through. Then switched to regular mix. Compression did not change much, maybe 3 psi tops. It did smoke a bit, but not as much as expected. The spark plugs did come out nice and clean though! Added the remaining 8 oz to the main fuel tank.
Will have it in the water tomorrow and I'll see if it runs nicer under load.
