BrianTindall
- Mar 8, 2004
- 165
Hello all. First posting here so bear with me! I did the search and found some good info but not exactly what I was looking for, so help is needed. Here is what I have: 1988 3.0l Seadrive with a new powerhead (less than 100 hrs) removed from boat, 1988 Johnson 225 ( 3yr old powerhead with 90 psi all around and possible problems) going on my boat with a bracket, and a 1984 2.6l Seadrive (less than 400 hrs) which I see will not work with the newer motors. I'd like to put the 3.0l seadrive ph on the Johnson frame, info indicates this is possible because both are "Loopers". Is this true and possible? What other parts would interchange? When I'm all done, the Seadrive parts will not be needed. Is there a market for them? Most of the parts are in pretty good shape.
