Re: Seadoo rotax Impeller
View the leading edge through the intake grate under the ski and view the trailing edge through the outlet.If either edge has any damage it should be removed and replaced along with a new wear ring..If the boat has cavitation it may need a new wear ring or you may have a bad seal in-between the ride shoe and the pump..
