I have a 1999 Crownline LPX that had a 5.7 with with a two-barrell carb. I replaced it with a 350 Mag MPI out of a 2002 Crownline. The new motor has a sea pump on it and I still have the Alpha outdrive. Can I run the two pumps in series? Can I put an idler pulley in place of the sea pump and just use the outdrive pump? (Will that be enough for the mag?) Should I block off the outdrive pump and put in a hull through pick-up for the sea pump? Or lastly, should I put in a Y between the outdrive hose, hull through pick-up hose, and the hose to the sea pump? Any help would be greatly appreciated.
