Sea Pro wiring diagram 180cc 1994 Please
kandil
Hello I have a 1994 Sea Pro 180CC with a 120HP Force outboard the same year I have the force shop manual and the weiring color is not the same as what is at the ignition SW I changed the ignition SW with a generic 6 pole SW with choke and it was hard to tell what wire goes where? the old ignition SW has some kind of insulation that covers the rear so you can not see the connection and it seems that the x owner cut and spliced some other weirs and I wanted to make sure that all the weiring is correct before I melt any thing:eek: so if any one has a wiring diagram for this boat I would appreciate it thank you in advance
kandil
Re: Sea Pro wiring diagram 180cc 1994 Please
No no one has it ^^^^^
phiml
Kandil,
Wiring diagram from the motor to the control for 120hp Force? No many Seapro has that motor. I used to have a bayliner with a 120HP Force in the early 90's. I can check my owner and service manunal to see if it has one. Give me a few days, I should have answer for you one way or the other. BTW thanks for posting the pics on the bait tank.
kandil
Hi thanks for the reply I have the force diagram but what I need is the boat diagram for all the SW and lights, pump and specially the ignition SW the colors don't match the force diagram!!
