Sea King
jhawk506
This msg is directed to "steelespike". I was told by rickdb1boat, Admiral, member # 9947 that you will know how to solve my problem. <br />I have a sea King by Montgomery Wards with the number "14KI8819" and #s "2167" under those numbers. I don't know what the numbers represent. They are located on the flywheel. I have no idea the size (HP) or the year this motor was made or where I would find a repair / operators manual. Also, where should I go to get help in getting this motor in operational shape again. I live near Rockford, IL.
steelespike
Re: Sea King
Im sorry I dont find that number.The model number usually appears on the mounting bracket.<br />Sea Kings were built by a number of companies.<br /> The mod. number will pin that down.In the meantime a discription will help.Color,number of cylinders,aircooled/watercooled,metal or<br />fiberglass/plastic cover.full gear shift,360<br />degree reverse,neutral clutch,location of the shift.throttle control,built in or remote tank/tank shape.Of course if you can figure out how to post a picture it would be easier.
