Sea King Motor Identification
Jim60
I recently purchaed a Sea King outboard motor. I think it may be 5 hp but not sure. Not sure of the fuel mixture either. Model number K7524106A. Serial number 1201125. One other number I found on it is Type N. XTV52370A. Any help would be appreciated.
Thanks,
Jim
F_R
Honorary Supreme Mariner
Re: Sea King Motor Identification
Thanks,
Jim
1976, 7.5hp, Made by Clinton. Air cooled, but the exhaust is water cooled. If the water pump doesn't work, the exhaust will get stinking hot, causing the powerhead to overheat also.
CEPCO (formerly Clinton Engines) 605 E maple Maquoketa, Iowa 52060. If you phone you may get info with contact info. Be patient. Ph 563-652-2411. FAX 563-652-3427.
