Sea king/Clinton need fuel pump diaphram
steve0323
I have two Sea King 7HP w/clinton engine, Model # J70011060. I need a carb for one and a fuel pump diaphram for both. Any ideas where to find these parts.
WillyBWright
Re: Sea king/Clinton need fuel pump diaphram
Welcome to iboats. :) <br /><br />I believe those use Tillotson carbs, so finding a kit should be fairly easy. Anyplace that sells lawnmower parts should have them. Finding a whole carb may be more difficult, but check around the mower shops. The diaphragm is going to be a little tougher. You'll probably have to fabricate one. My old 1960 Johnson 40Hp had a fuel pump with a rather large diaphragm that should provide you with plenty of material. I don't know the part number, but they should still be available and fairly cheap.
steve0323
Thanks for the guidance. I had actually thought of building my own diaphram anyway. Just thought if the kitw was available and reasonable, I'd go that route. I have found that a new fuel pump of a differnt style is the only alternative. Thanks again!
