Jeff Stalbaum
- Aug 2, 2009
- 11
I believe i have a 1970 (?) Sea King 9.6 HP in great shape. M/N is VWB27009A & S/N is 10643. Engines idles and revs fine in neutral and even seems to rev fine in gear while in a 55 gal drum of water. But on the boat in the lake under load, engine bogs badly until it dies. Removed the flywheel, cleaned the points (they were bad), regapped to .020. Everything else under there looks like new. Only carb adjustment i find is a screw on top the carb, parallel with intake throat. Regardless of screw position, engine runs the same. Not sure how entire fuel delivery system works. Not sure if throttle plate timing is 100% correct. All i know is it ran fine for years and 1 day started this BOGGING issue. Yes, the gas is fresh at 50:1 ratio. The fuel tank is even older with an adjustable vent in the cap. Should it be open or closed while operating. Any recommendations to end this mystery would be greatly appreciated. Also, i would love to find a manual for this engine. Tried Ken Cook's without luck & the closest i came on iboats is for a Chrysler but nobody listed a 9.6 that i saw. Sorry for the length of this post. Just trying to be as specific as possible. Thanks again, Jeff.
