Replaced my Alpha 1 gen2 drive last year with an SE116.The original one was working fine but,since I was replacing the engine,I decided to replace the transom assembly and outdrive also as I enjoy offshore fishing the most and wanna be safe,reliable and ALIVE.Well,17 miles out this wknd,I lost forward gear.210 hrs on new motor and drive since last July-Aug.It just gives me a kind of grinding noise when trying to put it in forward,like it sounds if you put it in gear too slowly,gggggg.Reverse works fine.Haven't pulled it off yet was thinking I need to disconnect the cables inside and see if I can shift it manually(motor not running)and see if the prop still turns cc.Right now with it in gear,(shift lever on lower unit appears to be positioned straight forward)If I turn the prop cc with some force,it will force the lever over toward N and prop will turn.I can't even hold that lever in place by hand.I'm thinking my F gear has a sheared tooth.Any Idea why?Will laying on the throttle too hard on take-off do this?Dosen't seem right.I think these drives are rated for 300 hp.My new carbed 5.7 is only 250 or 260.Also think maybe I should install a shower since I often push it pretty hard.Not running it like a raped ape but,when fishing the ocean with swells,current and wind,sometimes working EVERYTHING pretty hard just to push along.It's like hole shot,continously.3500-4000 rpm and just won't get up.It's just the water though because i can go other directions ok.
