bigmikek
Thread starter- Joined
- Jun 18, 2013
- 79
I had another thread on an impeller situation recently. Got the right parts and put it together right. I was so proud of myself. I got it back on under the upper unit. I had left the shifter in forward when removed and when I got it all bolted on I went in the boat and it won't go past Neutral into reverse.
I removed it again, had a friend shift it some and the straight copper tube with splines on both ends at the forward part of the upper unit has a cotter pin in the middle and a really thin flat washer just hanging above the cotter pin.
It seems to want to hang down a tad ( maybe 1/4 inch and it will move in forward and Neutral and reverse. I put the shifter back in forward and carefully lined the splines up and tightened up the lower unit bolts again. The closer I got to having it totally bolted up the harder the shifting became. Eventually, I could not shift into reverse again.
Am I supposed to have this in forward during this part of reassembly? What am I doing wrong?
