A previous owner replaced the floor with aluminum. I pulled it back up to replace the very wet foam and found the gas tank screwed down with little aluminum plates. The screws go right into the tank?! They don't leak. I have the tank full and the boat is tilted pretty good so the rearmost ones have gas sitting right on the other side of them. No evidence of leaks even when I accidentally step on the tank and make the breather vent gurgle. Is that how they built them or was this done by PO? At this point replacing the tank would be super easy, but not cheap. To do it later will be both hard and expensive. Thoughts? It's a 1990 SmokerCraft SFS16. In attached picture, look just to the left of the pink foam.
