Easymoney85
- Jun 23, 2022
- 4
I have some screw holes in my boat floor where the holes have been wallowed out in the fiber glass.. What is the best fix..Can I get a longer screw and drill deeper
The holes are for the screws that hold the back seat in..You have to take the seat out anytime you have to service or do work on the motor..It is all fiber glass..There is like a 11/4 void underneath the floorwhat attaches to those holes..... that is the more important question.
I wouldnt go with longer screws, as if there is nothing below the deck where the screws are going, it serves no purpose other than creating a hole in the underside of the deck which WILL allow water in over time to rot said deck (if it isnt already gone, and the root cause of the stripped screws). If you know the deck is good nearby, and you can move the mounting points, I would do just that, and fill the stripped holes either with fiberglass resin or 5200 to help prevent water intrusion and rot. There are plenty of threads here of decks that have succumbed to the ravages of water intrusion and rot, so if you can, you want to avoid it at all costs
What boat?The holes are for the screws that hold the back seat in..You have to take the seat out anytime you have to service or do work on the motor..It is all fiber glass..There is like a 11/4 void underneath the floor
2001 four winns 200 horizonWhat boat?
