screw holes in hull...
chynafaith
Names Lance, and my Boat's Named "Missbehavin" She a
86 Bayliner Open Bow/85 force Outboard...i've ripped out all the upholestry and noticed the prior owner had the bright idea of SCREWING!!! down some
"car mat's" to the deck....well he missed afew spot's (4) and got the hull:confused: what an idiot.....can i repair these small holes from inside right? I already have PolyResin and some Glass. By the way this is my first post and been watching this site for awhile...already ton's of advice i'm following, just not clear on this one. Thank's
Bifflefan
Re: screw holes in hull...
Welcome aboard!!
As for the repairs i really dont have an answer altho you should get one soon.
I just wanted to be the first to say howdy....
allpoints360
The screws didn't go all the way through the hull? If not, you could fill with some 3M 5200 from the inside.
Good luck!
chynafaith
screw's went threw the hull, enough where 2 of them i can see daylight.
rockyrude
If they are just "punch through's" you can just clean up the outside and marine tex them. Makes for a small patch.
chynafaith
yeah they are just screw size holes, didn't think it was a huge deal but it was a decent reason to start posting on the board's. Thank's i'll look into the marine tex. Sound's like a quick fix. :cool:
notsunkyet
ok ive tried that stuff before and didnt have alot of luck with it... probably cuz i didnt read the directions lol no if its a hole well a hole is a hole is ahole. if you get to it from the inside then great use some resin/glass and be done with it
