Re: Scraped thru Gel Coat
Sure,no problem.If you need more info,just ask.One other thing,pick up a qt. can of acetone at wal mart too!Use that to clean up the area after sanding each time and if you get any resin on you,you can use it to clean it off.Use some rubber gloves when using it.It is not the best to get it on you.Safteyglasses too!<br />The trick to help you out on the gelcoat is after you put it on,cover it with some clear plastic,type that is used to make those clear folders,ones that kids use for school.What that does is it spreads it out and gets air out from under the gelcoat and fiberglass,saves alot of time sanding too!Just cut it to size.Those small gelcoat kits has wax added to them already,so air is not a problem for the cure.<br />Another thing that will help is,after you do your first sanding before any fiberglassing,tape off the area,box it off,add some plastic to the tape and outward.Put down a drop cloth under your work area too!
