Scott Atwater Bail-a-Matic 10hp
Huron Angler
There is a 10hp Scott Atwater available locally.
It's $300 and I like the motor. I'm curious if these are show pieces at this point or can parts be found?
It looks like it's an early 50s model maybe.
I have a 12 footer that I could use the motor on, and the price is pretty reasonable if the thing runs. The ad does not specify the condition so who knows.
link to photos
F_R
Re: Scott Atwater Bail-a-Matic 10hp
The ad has been removed. Did you buy it? If you did, I won't comment on the price.
Huron Angler
Ha ha...no I didn't buy it. I'm assuming that's a good thing based on your comment:D
So I assume they are good for bolting to the rafters and looking at primarily?
I think I will stick to OMCs for my 50s vintage kicker motor needs...since parts are easily found.
F_R
Actually, I would like to find a Scott Atwater 10hp for sale. I walked away from a nice one last week, the guy wanted about $140 for it. I hope your guy got his $300, but that is way too much in my book. Call me cheap.
tmcalavy
too much for that motor. scotts were good, solid workhorses...parts can be a problem with some models.
JimS123
My local dealer bought out a Scott Dealer that went out of business. He now sells Scott parts all over the world. I'd bet he could fix any model.
My "twins" are 1954 7.5 HP Bail-a-Matics. Got them at a garage sale a year ago for $12.50 each. One was a box of parts, but they were all there!
Huron Angler
^^ Wow Jim those things are pristine. Nice work, and a great find for $12.50 each:D
Do you run the motors in the water? I'm curious how the bailing works exactly.
JimS123
They have been run, but I don't have the bailer puck so I can't attest to how they work. I believe aftermarket pucks are available. Regardless, my boat doesn't leak so nothing for them to pick up.
I believe they connect to a vacuum line on the suction side of the water pump. Thus, the water goes into the normal cooling system.
I offered the guy $25 for the intact motor, and he accepted it with the provision that I take the parts as well. He bought the second motor just for one part - to replace a broken tiller handle. I fixed the handle and rerassembled the second motor. The powerhead was fine and I was only missing a few nuts and bolts.
BTW, both motors were repainted with Rustoleum and the new decals are homemade copies.
jaybow
Imhave some knowledge of Scott-McCulloughs, 7.5's. They have two impellers, one for cooling powerhead, the other for bail-a-matic [I didn' know it was called a puck] they are stacked . Motor con be run with only the powerhead one, if the top bailer one is left in place so as to prevent loss of coolant through bailer. I have a "puck" and a leaky boat so may get to use it soon!
Yer a thief!!!
F_R
You actually don't need the puck. It is just a screened weight to lay in the bilge. A plain hose will also work. Just don't let it suck up old bait and cigarette butts.
Hoggar
Jim S,
I have a spare puck from a 61 Scott/McCullough if you want it you just need to pay shipping, PM me.
I have a 1961 Elgin = Scott/McCullough I removed the impeller from the Bail-O-matic and plugged
the hole to the puck tube and my Elgin 40 runs like a top.
jdret
Hey Jim,
Here's my '56 7.5 I picked up. It's got compression and will fire. I picked up some parts from the Scott Guy for the cowl, fuel pump and water pump. What I need is a throttle ring/label. Were your's in good shape or did your local dealer provide one for you?
