Scarab Hull Rebuild
sailingseven
I have a friend who wants to buy a salvage Scarab that was involved in a highway accident the boat sustained some hull damage(see link Pics). I have good experience with fiberglass rebuild for corvettes, but have limited experience with boats. He seems to think that this is a quick fix. Any thoughts?
http://www.qcsadirect.com/Inventory...z=&pg=1&tpg=&rcppg=20&vtg=&fts=&so=5&ad=&bn=0
He went to see it and it runs well on muffs? I'm still worried about what may be lurking beneath the surface.
PS94
Re: Scarab Hull Rebuild
The glassing you'll be doing is different than the glassing you've done on 'vettes. Same technique and principle, but the loads a boat gets subject to are greater than a car...
As for quick fix, I'd say not, looks like you'll have to access the inside, and outside of the repair area, and do a bit of grinding...It was wrote off for a reason...
It's a sweet *** boat thought!!
sailingseven
Thanks I knew that the structure needs of a boat would be a lot more than a car. Now to convince him of this.
Tail_Gunner
Sounds intresting. Here is what would do get marine survery to document the depth of the damage. cheapest insurance you could ever get....Then post the survery here and let a memeber called opp's give you the news...He's quite good.
