santana 21 main sheet configuration
rbock1
I am restoring a Santana 21 sailboat and am having trouble figuring out the the hardware and configuration for the main sheet. I can guess that a double block should attach to the end of thhe boom and there should be blocks at the rear of thee cockpit. I need more detail than what I just stated. A written description and/or picture would be helpful. thank you, Roland.
seabob4
Re: santana 21 main sheet configuration
Roland,
Put the sails away, install a 502MAG mated to a Bravo 1 drive, and be done with having to mess with all those bed sheets!
Seriously, you need to post in the sailing category of this forum...;)
saildan
I am restoring a Santana 21 sailboat and am having trouble figuring out the the hardware and configuration for the main sheet. I can guess that a double block should attach to the end of the boom and there should be blocks at the rear of the cockpit. I need more detail than what I just stated. A written description and/or picture would be helpful. thank you, Roland.
Your boat looks like this, right?
W.D. Schock is/was the builder. You should probably contact them and see if an owner's manual is still available. --> W.D. Schock
Other places you might get assistance from people who also sail this boat are:
http://www.sailnet.com/forums
http://bbs.trailersailor.com/forums/santana/index.cgi
http://bbs.trailersailor.com/forums/santana/index.cgi/noframes/read/4228
http://groups.yahoo.com/group/santanasailboatclub
