Sandblast Intake?
bpgM6er88
Hi, I am currently installing a remanned merc 4.3 and the intake being used is off the old engine. There is a lot of surface rust in the cooling channels and i was wondering if it would be ok to sandblast it clean. I dont know if there is a coating that is supposed to be applied afterwards (to prevent bare metal against the raw water).
Thanks,
Brian
wca_tim
Re: Sandblast Intake?
I would personally take it to a local machine / engine shop and have them hot tank it. It only takes one grain of sand left behind from sandblasting to destroy your engine... I know people do it, but I'm not comfortable doing it that way personally
NoKlu
oops! and I used muriatic acid to clean his new intake. Dropped it in a large plastic container with a couple of quarts of the acid and in a few minutes we had a rust free intake. Make sure you use a acid resistant container though as we never and in about 10 minutes the stuff was coming through the bottom. The fumes are strong so use the propper equipment.
Dont sand blast it bead blast it bigger particals and they wont get left behind
