Sand in gas?
HoustonGator
I just bought a used boat and tried to take her for a long trip. I encountered some rough water and the engine bogged. I shut down the engine and restarted after a few checks. It ran just fine until the next patch of rough water. I concluded that this was a fuel issue. I thought that the separator was full of water of the filter was full of junk that was stirred up when shaken. I came home and found water in the fuel and what looks like beach sand in the tank. Any ideas what this is (if it's not sand) or how in heck it got there?
emdsapmgr
Possible the boat sank, getting sand in the fuel tank when it was underwater.
kmarine
Sounds like you stirred up the sludge in the tank. It is possible it could be sand, but could be rust or some other sediment. It is is normal for boats to have fuel issues after prolonged storage, especially now that we use ethanol in the fuel. Replace filters and when changing dump into a plastic container and read the sediment. some times we pump the tank into portable containers and start fresh. I add some old filtered fuel to my truck and dispose of it that way. fill boat tank with fresh clean fuel.
gm280
It does look like sand or fine dirt to me. But you shouldn't have any issue if you have a quality fuel filter. I would take the time to clean the tank out and verify it is totally clean. Then make certain your fuel filter is of fine enough screened to remove such particles. Also remove the fuel bowls on the carb(s) to clean them out as well if your engine is so equipped... JMHO!
Bonus Check
I just had a fuel tank from my Ferguson Tractor cleaned and coated because of fine rust. Cost me about $125 for the whole deal. Rust got bad enough to start stopping everything up.
