Sand/bead blasting
ed_hall1
Re: Sand/bead blasting
I purchased this sandblaster from Northern Tool about a month ago. This turned out to work like $#*%.<br />Northern_Blaster <br /><br />It constantly get clogged, even with the expensive media. I have taken it apart so many times that I could now do it in the dark. Now it just sits in the corner.<br /><br />One of my friends suggested this model. <br />Northern_BlasterII <br /><br />It only cost $20.00 and works great. The trick is to hold the trigger down with the hose out of the media, then insert the hose into the media with your other hand when blasting. If you do your blasting in a large cardboard box (outside as suggested), you can save most of the media for the recycle. I do have a sandblaster that produce 10cfm @ 125psi which also helps.
one more cast
OK guys, it sounds like those little blasters don't have blow back valves to unclog them. Take a look at my TiP blaster. it has an extra air hose and valve to force air back up through the sand valve or force air only out through the nozzle. Should be easy enough to put one on yours.<br />
tommays
<br /><br />i found one at a garage sale for 150 dollars about 10 years ago(look in the newspaper allways used tools for sale)<br /><br />putting in new glass and gloves right now but its sooooooo usefull if you fix stuff <br /><br />it runs a 2 cylinder 5 hp compressor hard but a good shop vac keeps it dust free<br /><br />tommays
JasonB
No chance to even get it out of the box yet OMC. Work has had me pinned down.
swimmin' for shore
I started a similar thread over in trailers and towing, and OMC bumped it up for me...thank you for that...I'd like to continue with some similar questions on this same thread, if some of you would oblige me. <br />Pressure blaster vs. gravity feed. I have an 80 gallon air compressor that does an average job of keeping up with my gravity-fed blaster. It's an old sears model, and does the trick. I want to go faster, though. What's the coverage difference between these pressure tank models and the gravity-feed? Any of your thoughts are, and always have been, greatly appreciated. Thanks.
Scaaty
Originally posted by Matty1000:<br /> Harbor Freight :eek: :eek: <br />Everything I or my friends have ever ordered from them has self-destructed within one hour of use.
Depends on what you get, AND what you expect from it. A sandblaster with no moving parts can't be much of a problem. Besides, I have one of the sandblaster types mentioned, a JUNK Craftsmen (3rd replacement under warranty) 3hp 12gallon 7.5SCFM@90 with which I have stripped motorcycle frames and parts no problem. Little slow, and as Lubedude said, it will collect water, which a firm whack against something hard will clear. Go for it. You might want to look at the handheld they have too..I just bought one.
one more cast
" What's the coverage difference between these pressure tank models and the gravity-feed" <br /><br /> No comparison, The pressure blaster will be way faster if you can supply the air fast enough. I gave my gravity gun away after using my pressure blaster.
swimmin' for shore
OMC, thank you very much. That's EXACTLY what I was hoping to find out. I'm relatively sure that my compressor will stand the work, but if it won't, I'll be buying a new one. I've been doing a lot of side work, so I guess it'll pay for itself.
