Salt water use flushing
trebot
Have a' 63 Gale [OMC] 40 hp which i'll be running in Florida part of year. This motor has been fresh water all it's life. Will use fresh water filled tub to flush. Is there anything I can add to the flush water to minimize salt water effects?
neutra salt or salt-away
make sure you rinse it off the motor as well.
Bentrod425
I'm using salt away on my 15hp OB flush. Seems to work well. Find directions on the website.
phillnjack2
Ensign
rinsing the engine in a tub !!! no point rinsing it in the same water !! all your doing is diluting the salt.
you need to make a flush system to go n your engine so you can run a hose on it to flush away salt and anything else in the water you've been in.
once its been flushed for 5 minutes or so then a tub with salt away to keep the engine clean, and then a rinse of fresh water again.
when using in saltwater it really is important to get the engine so clean,
good luck I hope you manage to keep a good regime with it.
Chris1956
Honorary Supreme Mariner
When that motor was manufactured, flushing was not recommended. Those motors are all stainless, aluminum and brass right? I am not sure why you want to start flushing it now after 50+ years.
Hose off the cover and exterior after every use. Hose off the block ( do not get water in carb), every once in a while. Grease the fittings twice as often, and she will be fine.
