Salt on cylinder head gaskets...leak???
schwartzbagrules
I have just finished rebuilding a 1987 Evinrude V-4 crossflow and am in the breakin process. Have had the boat in the (salt)water 4 times now, engine hours are probably around 2 or 3. I have salt build up around the cylinder head gaskets, as well as some around 1 edge of the rectifier gasket. I, most unfortunately, did not professionally resurface the cylinder heads - they were hand sanded with 220 grit sandpaper before being installed. I have recently re-torqued the cylinder head bolts after knocking the salt off and adding another layer of paint to the heads. The salt was back without the boat even hitting the water or running??? I will cold test and warm test compression as well as run it on the muffs to try and spot any leaks, however as of now I don't see any water getting out. Advice please!
dingbat
Salt permeating head gaskets is typical of a motor that has spent time in salt. However, I would be concerned after only a couple of hours.
The heads should have been milled as part of the rebuild. 220 sand paper is about 5 times rougher than required
emdsapmgr
The combination rectifier/regulator gasket should have sealant on the gasket-does it? The head gaskets used are the type that say "no sealer required?"
schwartzbagrules
dingbat I didn't have the heads milled...a super rookie oversight on my part. Will be ordering a new head gasket and attempting to sand them down with either emery cloth or the proper sand paper attached to a thick piece of plate glass. I'll also try and do the block surface that way without removing the powerhead. Wish me luck. Thank you for your reply!
emdsapmgr The rectifier was never actually removed as there were stuck bolts - it functioned perfectly before the teardown so I decided not to replace it. Observing salt around the edge of one side of the gasket is a safe bet that it could be leaking - however, I also observed a trail of salt from the cylinder head to the respective side. Although the engine was trimmed at a downward angle, I think it could be possible that the head leaked so bad that saltwater ran down to the rectifier before it had time to evaporate. Never the less I'll be purchasing some liquid gasket and going around the edges of the rectifier.
The head gaskets were OMC gaskets that indeed said no sealant required. Thank you for your reply!
