Sad Story Of Rage
cvanhyn
I purchased my first boat last summer, a 1995 BW Rage 14' Jet with a 115 HP OMC Turbojet. The boat had not been run for at least 8 months.<br /><br />There were numerous problems to fix before I ran it the first time. The only "major" repairs I made were to rebuild the starter and turbojet (new bearings and corrosion-proofing).<br /><br />When I finally did run it, I cooked the number 4 (port side lower) piston in about 40 minutes of operation. The piston got so hot it melted on the exhaust port side, with signs of pre-ignition. Note that I ran a rich fuel-oil mixture because I had verified that the VRO2 pump wasn't pumping any oil.<br /><br />I learned during this fiasco that the boat had not been winterized in the NE, and freezing had cracked the heat-exchanger manifold. I repaired that, spent about $700.00 rebuilding the power head (Wisco pistons, etc.), and took it out again, following the manufacturers break-in instructions to the letter.<br /><br />Well, the second running after the rebuild was a carbon copy of the first - I melted a brand new Wisco piston in #4 in exactly the same scenario as before, in exactly the same amount of time.<br /><br />I have it apart again, and I'll be damned if I can find anything wrong with it. I've had a local shop look at the piston, power head and reeds. They suggested my problem was old water deflectors and a double-firing power pack.<br /><br />I am a 4 cycle car engine kind of guy at the mercy of this money pit, and no one I have talked to can give me a conclusive diagnosis of this problem. Lots of theories, but no real answers.<br /><br />Any advice from any source would be welcome.
Joe Reeves
Re: Sad Story Of Rage
I'm not familiar with the "Turbojet" but am assuming that the "115" is a two cycle OMC type engine with more than one carburetor. If I am in error, disregard the following.<br /><br />Rebuild the carburetors. Due to sitting, they're fouled somewhat which results in having the engine (at least one cylinder) run lean. This (as you've discovered) results in pre-ignition, destroying the piston(s).<br /><br />Powerheads do not blow by themselves... something caused it! If you do not cure the cause, you will encounter a repeat of the problem (always).
cvanhyn
Thanks for the reply Joe.<br /><br />Of course, I think you are right. My biggest mistake on the first rebuild was not rebuilding the carbs. I didn't know that 2 cycle engines can self-destruct when they run lean. 4 cycle<br />water-cooled engines just run bad.<br /><br />I was fooled by the cooling system leak. I thought it was responsible for melt-down.<br /><br />I will rebuild the carbs this time.<br /><br />I will also put a temp gauge on the #4 cylinder, monitor it carefully, and shut the boat down if the temperature exceeds 150 F.<br /><br />Any other suggestions?
Joe Reeves
In the bottom center portion of the carburetors are the brass fixed high speed jets (one for each cylinder). If dual carbs, two high speed jets to a carb.<br /><br />Clean them manually with a piece of mechanics wire, a paper clip, something of that nature. Soaking them just doesn't quite do the job.
D
DJ
Guest
Conrad Van Hyning,<br /><br />Joe, is spot on, as always, about the carbs. <br /><br />The deflectors can also cause an overheat. Since you have the heads off anyway, defelctors are cheap.<br /><br />My be is on a lean carb.
