nola mike
- Apr 22, 2009
- 5,835
in the market to buy my first boat, though i grew up around them. i'm looking for a late 80's/early '90's 18-21' bowrider, i/o, to be used in brackish water, likely trailered (though i'd rather not...we'll see) when i won't be around. boat will be used for cruising, skiing, and fishing, probably in that order. a few questions:
1. should i be looking for a closed cooling system, or does it make much of a difference? which engines had them?
2. any particular minimum engine size? i'm looking for a top speed of 45ish, ability to pull a 200# slalom skier at 33ish.
3. most important: what should i look for prior to purchase? i'm pretty handy, and could probably fix most problems myself. i'd like to avoid missing something major, like a bad block (i'll compression test) or outdrive (i don't know how to evaluate that).
3a. i'll be looking at a couple of boats next week with omc cobra drives; i've seen something about bad shift cables destroying gears. anything else i should look for?
3b. most of these seem to have merc alpha 1 gen 2 drives--anything particular to look for here?
4. any way to evaluate the condition of the subflooring, except looking for spongy points? where should i be sure to check?
anything else i'm missing?
