S.L.O.W. system activation on my 1998 engine
G
Guest
Guest
The 1998, 150 on our pontoon boat continues to activate the slow system after 30-45 minutes of operation. We have replaced the impeller and both thermostats. We've tested both temp sensors and they consistently close at 240 degrees. (white/blk wire sensor closes at 115 degrees) We have a strong indicator stream as well and inlet screens are clean. Can anyone advise us what to check next for a cause?
Honorary Supreme Mariner
There may be a blocking diode in the wiring harness parts.--Have your local shop check that out.
G
Guest
Guest
Hey thanks boobie... I've been considering this too as the cause. Do you know if there is a test protocol for power packs?
G
Guest
Guest
Hey thanks racerone...I'll look at the wiring diagram for this blocking diode and give it a test.
boobie
There's a procedure in the factory service manual for checking this diode.
G
Guest
Guest
Ah yes, the factory manual! The diode test procedure was an easy and straight forward one to conduct... and the diode checked good. It's looking like a malfunctioning power pack. I downloaded the 18-5887 (now 113-4985) Installation PDF from the CDI site but don't see a specific test to isolate the SLOW mode circuitry.
