Rusted surpentine pulleys
then you have had better luck than I have with rust conversion.
chartersj
Still trying to figure out exactly what I'm going to do. Still winter here in Canada but weather is getting better all the time now... I was wondering if anyone has tried the 2k spray paint that Eastwood or spray max offer? It's primer or paint that you activate the catalyst for a one time use. Seems like it may be good option for me.
Ayuh,..... I've never heard of that system,......
My preferred system is Rustoleum, primer, 'n industrial enamel,......
chartersj
Just got the boat out of storage and figured I would give an update after having the pulleys painted for a year. On the inside( belt does not run on), I rust converted and used single stage rust coat paint. On the outside and rest of the pulleys I used a rust converter, a 2 part epoxy primer, and then a 2 part top coat. I used spraymax brand that is a one time use with catalyst activator in a spray can.
tank1949
After having my first motor with surpentine pulleys for a couple years now I'm getting tired of them always needing attention. Both years I have had to wire brush/sand/file the groves down and re paint them. The paint wears off quick and then the rust starts. The belt dust makes a big mess in the engine compartent and also cannot be good for the motor when it gets into the throttle body. I boat in salt so that obviously accelerates the rust, but it makes me miss the v belt system on my previous motors. That being said I'm looking into replacing the main pulleys this year. I noticed an aluminum raw water pump pulley on eBay, I know aluminum will oxidize as metal rusts but wondering if that would be better and one less pulley to work on as much if I did replace that one with aluminum?
Try Ospho to treat iron/steel. Amazing results!
