trent_tweeter
Thread starter- Joined
- Apr 25, 2008
- 53
'68-55-evinrude-55873R-has issues.
Starts instantly when cold with choke. Will run perferctly for 10-15 minutes ie slow med fast back to idle changing gears etc. After 15-20 minutes of running if slowed down to idle it will stall and then wont start for at least 5-10 minutes choke or no choke. If water is splashed on area of cylinder head where thermostat resides engine will start before waiting 5-10 minutes. I removed thermostat but problem still exists. Seems as long as it is running above half throttle and not brought down to idle it will literally run happily all day. Can't take the kids skiing with the situation as is. Rewired the entire motor under shroud last year and problem is still the same.
Any advice would be appreciated.
