Runs great for 3 min while cold then shuts off
Drock7
94 Johnson 70 will run great if it's been a day since it ran for 3 min. Running perfect on muffs it's like I have turned off the key, it will shut off and only turn over. I have check spark and there is none. The neutral switch is good and so is the key. It's getting plenty of fuel.
emdsapmgr
Weak ignition components tend to fail due to heat. Most run fine when the engine is cold. Once the engine warms up to normal operating temps, a component can abruptly fail. It may run just fine again once the engine cools overnite. So, once the engine shuts off, you should check the voltage outputs on the stator, timer base and the power pack. The troubleshooting info at this website is most helpful: cdielectronics.com Since these components are all pricey, some analysis time on your part will make sure you replace just the failed part.
Faztbullet
Disconnect rectifier and retest, it still fails check stator and timer base.
